Torn boot on rear factory drive line
benatc1
Hey all! Managed to peel off the plastic covering on my rear driveline last weekend, seems to be functioning fine at the moment but thoughts on how long I might have until I need to replace it. Plan is to go to a 1350 at some point but funds aren't exactly where I'd like them to be so trying to hold on a bit longer if you think it's possible as is. Thanks!
benatc1
Not yet it's been over a month but I have gotten the driveline to expand to get new grease into it
Good to know, thanks!
I think you can squeeze a few month of that shaft easy.
Let's hope so!
Been running mine that way for 4 years. Lots of off reading also.
Thanks for the info, good to know it'll likely last till I'm ready to upgrade
JeepJeep75
I guess I went way overboard when I only put a little rip in mine. I'm holding out for an upgrade too. [emoji106] Crazy how a torn boot can cost over a G to upgrade after you get a new DL and adjustable uppers. Ahh JEEP. [emoji847]
J
JKDream
Guest
It's just a slip joint, you really don't NEED the boot.
Double Cardans have the same style joint and don't run boots.
It's the transfer case CV boot you don't want to rip.
