Dealership just called and said that the steering shock was blown and that they could easily move it in and out with no resistance and that was the only problem they found to resolve my issue.. Everything I've read says this will mask the problem but make it seem fixed kinda frustrated right now. Also he noted my lift that I have the springs are week as it is causing my jeep to lean to the right. I than told him that it was a leveling kit and that the springs are new. They are the Evo plush ride springs. And were installed correctly. And it has always had a lean to the right since I've owned it smh... Hate dealerships
Its because you are squeezing the two ends together so there is linear force along with the radial force. At least that's what the Airplane mechanics tell me.
Either way I have to get this fixed its my dd and with less than 3 months to go till my son is born it's gotta get done... Ugh if the weather was just a little better I'd be a lot more happy bout having to do the work
Ok so again with vehicle lifted I checked all ball joints for play and aside from the typical forward and reverse rock that you get with the ball joints it's all tight.
Caster angle also have not checked or no how
The typical movement you get from the ball joints is what I was referring to.. And as far as the track bar bushings go I didn't check to see if it was wallowed out just checked the torque on it and there was no wheel movement when I checked the wheel bearings in any direction
Is that right... Must be a good mech!
Well I trust my life to their work so I sure hope they know what they are talking about. :idontknow:
Ok so the typical movement I'm referring to is when you grab the tie rod or drag link and you have the pivotal motion front to back. There is zero play side to side or up and down.
That has nothing to do with ball joints.
I think he was making a joke. He used to be one.
