Dune Crawler
Once you start building and adding mods you won't be able to stop
so after reading what has been said he about going 3in and over with a lift and needing a new front DS and a rear, would yeilding extra height come into effect even with the smaller lift?
now running the 2.5 for you guys with the 35's have you "had" to swap out DS's? what other things were essential for the smaller lift? or can you run stock drivelines for a while. with mine will mostly be a daily driver and then when im allowed time off a weekend rig to go to the better camping spots
First jeep and first vehicle in the family to lift and mod so I'm the same boat as you. I went with a RC 2.5 suspension lift and 35's View attachment 64708 View attachment 64709
Mine (right) vs a jeep running 33's (left).
It did on mine. The manufacturers advertised lift height is based on a fully loaded rig. As least MC is. I have steel bumpers, a tire carrier, sliders, and a hard top and I actually got 3-1/4" in the front and 3-1/2" in the back on the 2.5" lift. With the wheels I netted 4.5" front and 4.25" rear due to the added weight of the spare....
...I haven't been able to test full flex yet to see if the front DS rubs the boot, but I have read where a lot of guys are running stock just fine at that height.
My pinion angle is 4* and it rides like a champ.
Rear DS looks good and it's a 2 door.
Assuming you got shocks that will allow for a greater amount of droop to go with your coils, you WILL damage your slip shaft boot at a full flex. Of course, that's only part of the problem. If you have a 3.6L motor, the angle of your motor to transfer case is sitting at a steeper angle and that will cause your front drive shaft to sit at a steeper angle too. EVEN IF you didn't damage your slip shaft boot, your CV boot will be in a constant state of pinch and WILL fail prematurely because of it.
It "looks" good? Honestly, I don't know how you could say that if you really got 3.5" of lift in the rear. Anyone with any experience working on JK's knows that at about 3" of lift, a 2-door rear drive shaft will sit at steep enough of an angle that the output shaft and pinion CV boots will be in an constant state of pinch. Most people can get about 2 years of use or 30,000 miles but, if you're flexing your Jeep at all, it'll be less.
And my plan is to replace it with a Coast 1310 when it does.
I was basing that statement on what I was told on other forums based on pics I posted.
Nice lookin' rig. I think 35s are the best all-around wheels because they look awesome (biased, of course) and minimal drive train mods right off the bat. As I wear parts out I'll upgrade as necessary.
Sorry. I thought this post made it clear. I'll be more specific next time. I understand that lifting a rig requires more than suspension and wheels. But the additional costs are reduced with a lower lift. That is the only point I was trying to make. I willl refrain from sharing my little experience in the future. I just like to try to give back when I learn something but am by no means an expert. I'm just glad we have experts to chime in when necessary. So how does the rear DS look to you in the pics? Change it right away? Or can I get some miles on it? Thanks in advance.
well i have to say, this is my first post to the site and its awesome to see the support and knowledge from everyone, makes ya know you have joined the right, and best forum. for the angles of DS where would you start looking at replacing DS and what affordable DS f.r would be the best bang or the buck? all soo new and almost overwhelming, awesome everyone likes to share!
okay great, thank you for the visuals, helps out a lot to see it that way. when looking at different rear D/Ss with the 2 1/2-3in better to get a enforced replacement? or one that is set up for a lift? sounds like a dumb question to me but knowing me i go about the wrong way... murphs law and allAs mentioned, I would just keep an eye on what you have now as they will let you know when they are starting to go. When the CV boots start to fail, they will spit grease out on to the bottom of your tub and gas tank skid. Once you see that, it's only a matter of time before you start to hear it ratchet. When that happens, you are done. I would just keep it in mind to save up for a new front shaft if you have a 2007-11 with an auto or any 2012-up. If you have a 2-door, I would keep it in mind that you will need to replace it sooner than later as well with any lift 3" or more. you will also need to get adjustable rear upper control arms to set your pinion angle when you do so keep that in mind as well.
