My vehicle in stock form is a 2 door 2011/12 Sahara with a 2 1/2 inch Terraflex spring lift with shock extensions. Tyres are Mickey Thompson 285/70/R17 Baja MTZ. They're about an inch past the fender so I'd be looking to correct this. Also I don't want to have to chop or replace the fenders.
Because you do not want to chop your fenders, I would recommend that you install a 1" body lift. This will get you the needed clearance you'll need for 35's and do it on a budget.
Tyres
The Mickey Thompson tyres I currently have are expensive at £230 each ($390). So, I would be interested in a cheaper aggressive mud tyre as I have to multiple this by 5 and I think I could possibly save several hundred £££'s here. They need to be good for the road though. What do you recommend? No all terrains please.
I might look at a set of BFGoodrich MT KM2's. They should be readily available in your neck of the woods, will wear like iron and will get the job done for your needs. Even if they cost a bit more than other tires, they'll save you money in the long run.
Axles
As this is the Sahara model will I need some axle strengthening? What are my options here and if you don't mind can you point me in the right direction of manufacturers parts.The only off roading I do is with the UK Jeep Owners Club three or four times a year and is mainly mud based, apart from that I stay on the tarmac.
As mentioned, you'll benefit from installing a set of c-gussets as the larger tires will cause them to bend otherwise EVEN IF you never off road your Jeep.
Gears
Mine's an auto on standard gears, will this be OK or do I have to consider re-gearing.
You will always benefit from regearing to match the tire size you are running if for no other reason than the fact that it'll bring your performance back to stock or better. This is REGARDLESS of what motor you have. Depending on what you have now and if you don't do too much driving on hills, you can get by.
I have a Terraflex tire carrier and hinge on its way from Quadratec.
Being that you're on a budget, I would cancel this order if it isn't too late.
http://wayalife.com/showthread.php?4740-TeraFlex-Hinged-Tire-Carrier-Break
Hi Paul, log onto AusJeepOffroad. We have the same engine in our market as you. Lots of guys down under who can help. :thumb:
As others have mentioned, I personally would appreciate it if you could just answer the question as I just have rather than suggest a member here go elsewhere to find it. I may not have the same motor as you but, it still didn't prevent me from providing ACCURATE information regarding the question being asked. I'm not here to argue with you, just asking you to show me some courtesy.
