Changing the differential fluid on your Jeep Wrangler JL or Gladiator is something you should do as a part of routine maintenance and or any time you've been playing in water deep enough to submerge your entire axle. And, while drain bolts are no longer present on mid 2021 and up models, the process is still quick and easy to do and thanks to the reusable diff cover gaskets that are now included in their place. This video will show you how to save a lot of money by doing it yourself, in just minutes and with a few basic tools.
HOW TO Service a 2018 - Mid 2021 Wrangler JL & Gladiator
Differential Service WITH Drain Bolts
WHAT YOU WILL NEED
Valvoline 75W90 Synthetic Gear Oil: https://amzn.to/47FrCC7
Valvoline 75W140 Synthetic Gear Oil: https://amzn.to/47FaCvL
Teflon Paste: https://amzn.to/3KAfzfU
Oil Catch Pan
3/8" Drive Ratchet
10mm Socket
15mm Socket (Gladiator)
Torque Wrench
Brake Cleaner
#jeep #wayalife #differential #jeepwrangler #jlwrangler #wranglerjl #jljeep #jeepjl #wrangler #gladiator #jeepgladiator #gladiatortruck #jeepjt #jtjeep #jeepgladiator #differentialservice #differentialmaintenance #diffservice #diffmaintenance
* Jeep parts purchased through the Amazon links provided will help support this channel.
WHAT YOU WILL NEED
Oil Catch Pan
3/8" Drive Ratchet
10mm Socket
Torque Wrench
Brake Cleaner
