Rock Hard 4x4 Spare tire license plate relocator.
And the pieces are coming together :yup:
Is this for changing ball joints on your JK? If so make sure you have the angled adapter you need it to press either upper or lowers straight, I don’t really remember which ones.
I used this set, it had the angled adapter. The press was just barely big enough for ProSteers. I leased it form Advance auto parts
can't wait to install this
Whoop whoop!! Back to good[emoji106]. Should have done this a long time ago!!!
strictly for daily driving use as my sub box rakes up the entire trunk space which I need for tools when off roading. I'm a sound guy so I like to make the best of the vehicle I've got! I’ve experienced great customer service with Adams drive shafts. I need a rear soon, so I’m jealous.
Yes. I wasn’t sure if it had the correct adapters, but I figured I could find one.
More goodies for Martha. View attachment 280094View attachment 280095 strictly for daily driving use as my sub box rakes up the entire trunk space which I need for tools when off roading. I'm a sound guy so I like to make the best of the vehicle I've got!
Sent from my Life One X2 using WAYALIFE mobile app
I'm trying to find a non under seat option that's not all the way in the back. I'm worried about water for doing and frying the amp. I have 2 10s off of this mono block and a small booster block putting my 4 speakers at 45w rmsNice, I have a 5ch amplifier mounted under drivers seat, it’s out of the way. I run 10” sub which I can easily remove. I got a cheap little sub in the factory enclosure for when I need cargo space. Dynomatting the inside of factory enclosure helps a ton but it takes a while to do.
