Ah2014jk
Hmmm so many choices, I'll take Moby![]()
I think Eddie might come with that one so that would be 2 things
A new floor board! The original owner decided to glue down the carpet everywhere and it was quite fun to take out :doh: ...I ended up taking the jeep in and they still could not get it all out so I have glue/residue left all over that will not come off.....(will ultimately cover it with a bed rug kit or rhino line it)....
Or
Someone to make a trail rack that will work with the SmittyBilt bumper/carrier I have.....:thinking:
For the glue use Nail Polish remover and a heat gun (hair dryer will work). Heat the glue up and then use the nail polish remover.
or soak it with brake cleaner. It tends to dissolve adhesives (and plastics so be careful) well.
To live closer to better trails! :daydream:
But since that probably doesn't fall within the rules here, I'd ask for a fully loaded Manley ORV trailer (full slide out kitchen, onboard air, water and electricity and a rooftop ARB tent.) That's just one thing!![]()
Thats mine, Fully Equipped Adventure trailer, built and loaded to my spec's :clap2::thumb:
wel, acetone is the main ingredient in nail polish remover and it will remove paint.
Sucks they couldn't get all that carpet glue up but it really can be removed...
did you try hot water (boiling) and some plastic scrapers on the floor portion?
let the hot water soak and it does soften the glue so you can scrape it off.
The sides might be a challenge but I'd lay old towels soaked in hot water on the sides and then scrape after it's softened up the glue.
Problem I see with a heat gun is the potential to cause the paint to blister or burn your skin as you scrape.
either way it's tedious and after you remove the glue you'll likely still have to paint over it.
another method I've used to get melted stuff out of the seats, use old towels and an old solid base iron...iron over the towel/glue until it softens. the heat should draw the majority of the glue onto the towel then use a good adhesive remover on the residue.
or....... it's like let's make a deal here ll
bedline the tub and sides to hide the remaining glue and then lay the carpet kit over it.
That's winning so far
I would love a garage.
I'd like to retract my previous request for a pr44 and take what you're having haha. Another month or two and I'll be wrenching on my JK with a snowsuit on.
Wouldn't the trailer be one item? Then every other piece that goes with it a separate item?
