Oil Viscosity
I switch to Amsoil at the first oil change (about 500 miles) and have run 5W20 ever since, changing oil once per year.  I have 56K and run 75mph highway for hrs at a time, routinely with 33's.  I run 35's on the trails and the oil pressures stay relatively the same as highway.  I put a sandwich plate on the oil filter to pick up a pressure.  Not saying this is the most optimal pick up point, at the filter, as pressures change pretty dramatically based on RPM's.  If this engine ever pukes, and I have to pull it for an overhaul (I like the 4.1L overhaul), I will find a different place to pick up oil pressure.  One thing about Amsoil is you have to use their prescribed oil and filter based on your vehicle make and model, or they will not cover engine damage.  I have since changed everything over the Amsoil fluids.  The preferred member is worth the cost to get cheaper pricing...and you typically change once a year.
