Stand alone motor, gutted any factory wiring not needed. Gen 3 LS, TH 400 trans
Installed a gas neck with a check valve in Franklin
And no pics but I put a remote start in too, and it actually worked meow
What remote start did you go with?
So the gas doesn't spit back out at you.Forgive my ignorance, but why a check valve?
The early jk came without it and it can cause issues when trying to fill the tank. Mine kicks the gas pump off about every 30 seconds when I fill it and I have to use the lowest lock on the handle. I think when they moved to the 3.6 they started putting the check ball filler hoses in.Forgive my ignorance, but why a check valve?
I read it from someone else I think in this thread even. It is Remotestartx
off Amazon. Was pretty easy to install actually
Ooh right, I think it was this thread. Thanks!
That's the one I did a couple weeks ago. Very simple install. The only downside is you have to hit the lock button 3 times so the horn honks 3 times. Could unplug the horn I guess. But overall it does what its suppose to do, cheap and easy install.
Hers is a sport without power locks so I got the one that came with it’s own remotes, it has a receiver thing I fished up the A pillar and tucked in the roll bar padding hoping for maximum reception. On this you push the button once for 2 seconds and it starts. I think the nicest thing is if it breaks you can take it out and no factory wiring was cut or spliced
At least this was my understanding.
That’s badass. I wish I could bring myself to do that lol
Oh that's cool. Easy peasy. What's the range like on that one?
Are you able to retain AC, turn signals, etc with the stand alone harness? Or have to run separate wiring?
