Finally got the replacement light bar "unibrow" installed after it was stolen a while ago. Next ass clown that tries to steal this will be in for a surprise when he realizes all the bolts are spot welded!!!
Installed a backup camera and a couple Rigid SRM backup lights.
What tail lights are you running? Those would simplify things immensely.
Josh. These are the same I've had on my rig for about a year now. Still really happy with them.
Done deal Jason!! Thanks, those are perfect and cheap. Take care bud.
Got some new Ten Axles for the rear Dana 44. That bent flange was driving me crazy.
little squeak every time you go straight lol? i have to do mine in the next couple days post up some picks of your swap! are you changing all the breaks and stuff as well?
Dang that squeak! Lol Plus one side of my axle was leaking in conjunction with the squeak. I've already did the install, my phones camera was jacked up at the time & wouldn't focus so I didn't take many pictures. The install took me less than an hour thanks to Eddies right up. It was pretty straight forward. Make sure you get the shafts with the Bearings already pressed on that made life so much easier. If you decide to go with the Ten Factory ones they are 414$ at Northridge with the discount...I did replace the rear pads & rotors I figured after 112k it was time. Lol
Here's that right up Eddie did. http://wayalife.com/showthread.php?...-Axle-Shaft-Removal-amp-Installation-Write-Up
i got 4 stock shafts for free and i just bought bearings to rebuild them lol but that squeak omg lol, did you think you pads or rotors were toast from it, I just changed mine like 10k then bent it over the winter?
Gotcha.....I'm not sure but I would think that your brake pads & rotors should be fine. Mine didn't look like anything was wrong with them just a little wore out from all the miles.
Mounted a Powerplant winch that I picked up for $700. It was a tight fit with lots of grinding and drilling. And it is still slightly offset by 3/8". Also raised the rear shock mounts both upper and lower.
View attachment 142447View attachment 142448
After dumping my top on the concrete and doing fiberglass damage, I got to learn how to do bodywork. View attachment 142251View attachment 142252
Maxxima (M85416R) Red/White Round Rear LED Stop/Tail/Turn/Back-Up Light https://www.amazon.com/dp/B00IZG63DE/ref=cm_sw_r_awd_hyVtvb0TACAWA
