I thought they started selling the rear brackets alone. I tried looking at Northridge but I'm not used to the new website. Maybe on ore website
i stand corrected. last time Drew@ore was on and we had a very similar thread going on he mentioned it was an in house only task so they might have changed it.
Not according to the conversation I had Tuesday with EVO, they said it's in house only. I asked that exact question, idk...
do you have a pic handy of your rear axle that would show what has to be changed in order to run the high clearance kit
hope you dont mind the thread hijack but so out of curiosity can you run a single throw down on the double throw down EVO lever so you can upgrade later??
What kinda flex/performance difference is there between the Evo Bolt-on COs with the long arm upgrade and the Double D with king 2.5s?
I know I didn't ask for the pictures but I honestly have no idea what is being compared in the pictures or what is being looked at. I know the brackets are but not sure what exactly. Could someone explain?
The picture I posted was for the high clearance rear axle brackets. if you look at the location they are rotated up about 90 degrees from the factory lower control arm brackets. secondly that is a bracket that ORE will only install in a house with the bolt on coilover bracket on the rear of the axle. this is not a bracket they sell over the counter according to EVO. A long arm kit does not give you any more flex, it basically corrects the geometry after lift is installed which allows for a much better ride and handling. You get your flex and your suspension travel from either your coilovers or springs which are limited by your shocks. Coilovers give you a much greater drop in the suspension which will allow much better flex. The difference between the bolts on long arm in the high clearance is the brackets for the high clearance are mounted on the side of the frame and the axle bracket is rotated up to give you higher clearance versus the factory bracket. This keeps the brackets away from hanging on the rocks. The bolt on long arm kit uses the factory lower axle control arm bracket and is bolted underneath the frame like the factory control arm frame brackets. Hope this helps.
