Really, I guess I stand corrected then. I'm solely going by what I've been told from people in the off road industry and from what I've read online...my bad
In all fairness, the general guideline is to get a winch that has a capacity that is roughly double your vehicles weight. For a JKU that weighs about 5,000 lbs., a 10,000 winch would fit the bill. Having said that, most people will never be in a situation where pushing the capacity to the limit is needed and, even if it is, the right tools and knowhow will make all the difference. :yup:
Now you tell me. I have EVO working on a custom front bumper we've dubbed the "1/4 ton'er" to hold this 40,000 lb mooring winch. Do you think it will impact airflow to my radiator?:cheesy:
LOL I think if the bumper is engineered correctly you may get enough air to pass on the right side. Either that or mount it inside the Jeep with a pulley system routed under the jeepNow you tell me. I have EVO working on a custom front bumper we've dubbed the "1/4 ton'er" to hold this 40,000 lb mooring winch. Do you think it will impact airflow to my radiator?:cheesy:
Just was wondering if its worth the time using a snatch block as opposed to paying a little more for more power. I have no experience at recovery.
Sent from my SAMSUNG-SGH-I337 using WAYALIFE mobile app
What I can tell you is that the vast majority of people who own a winch will never use it to do more than light recovery and never come close to needing the full extent of their winch's power. If you're at a point where you need to use a snatch block, chances are, you would have needed one with a winch that has a bit more capacity too. If you're on a budget, an 8,000 winch will get the job done. If you can afford it, a good 9,000-9,500 winch is what I would recommend - I can't speak for anyone else and I'm sure they are way more badass than me but, for my purposes, it's been all that I've needed. If you can afford it or want to spend more, a 10,000-12,000 winch won't hinder you in the least other than to your wallet.
Just curious, with minimal use, what is life of a winch. What I'm getting at is I'd they last many years, I'd be more inclined to spend more now.
My Warn M8000 is a 1980's model, and still pulling strong. It's on it's second vehicle now.
I researched winches for about 2 years before I settled on the warn power plant. I have no regrets.
To not start a new thread...what do you do when there are no trees around and you are stuck?
