Ordered the ProRock today! Thanks to Steve at Dynatrac who was very helpful in making this happen.
I do need some help regarding the steering. I am probably going to have to make a custom drag link. To start with the drag link assy will be about an inch longer. The knuckle end will be a typical hi-steer JK.
The end at the pitman arm will be WJ. The upper link for WJ and JK is different. The JK not only has larger thread diameter doing in to the drag link sleeve but also has a larger and different stud taper that meets the pitman arm. I DO NOT want to ream the pitman arm. I want to leave the pitman arm and the upper link as a WJ style. I think I may just take the parts down to a machine shop and have a custom adjustment sleeve made. Anyone else have any other ideas? I want to be able to retain the adjustment sleeve to center the steering wheel without disconnecting ends.
