darkknight1999's Build thread
Brown Santa brought me gifts of light (CREE 50"led bar) and stability (Synergy front ball joint set)
Sent from my NSA monitoring device... Using the WAYALIFE mobile app
My Amsoil fluid shipment arrived today :D
Engine Oil (Filter) • Absolute Efficiency Oil Filter (EA15K51-EA)
Engine Oil (fluid) • Synthetic 5W20 SS Motor Oil (ALM1G-EA )
Transmission (fluid) • Synthetic 5W30 Manual Trans (MTFQT-EA)
Engine (flush) • Engine & Transmission Flush (FLSHCN-EA)
Diff/Gear (fluid) • Synthetic 75W110 Gear Lube (SVTQT-EA)
Transfer Case (fluid) • Synthetic Multi-Vehicle SS ATF (ATFQT-EA)
Fuel Additive (Injector Cleaner) • ORMD Quick Shot Fuel Additive (AQSCN-EA)
Brakes (fluid) • Amsoil Series 600 DOT 4 Racing Brake Fluid (BF4SN-EA)
Here's more information for those that are interested:
LUBRICANTS & FLUIDS:
Engine Oil Grade 1......API*
Maximum Performance SAE 5W-20 Signature Series 100% Synthetic Motor Oil (ALMQT)
Performance Plus XL 5W-20 Synthetic Motor Oil (XLMQT)
Performance OE 5W20 Synthetic Motor Oil (OEMQT)
Manual Transmission,NSG370 (6-SPD)......GLS [1]
Synthetic Synchromesh Transmission Fluid (5W-30) (MTFQT)
Automatic Transmission,42RLE......AP4
-------Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
-------OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Differential, Rear W/ 198 RBI W/O TT......GL-5
---All TEMPS......80W-90 [2]
------SAE 80W-90 Synthetic Gear Lube (AGLQT)
------SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
------75W-90 Synthetic Long Life Gear Lube (FGRQT)
------SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Differential, Rear W/ 226 RBI W/O TT......GL-5
Differential, Rear W/ 198 RBI W/ TT......GL-5
---All TEMPS......75W-140 [2] [3]
------SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT)
------80W-140 Synthetic Long Life Gear Lube (FGO05)
Differential, Rear W/ 226 RBI W/ TT......GL-5
Differential, Front W/ 186 FBI......GL-5
Differential, Front W/ 216 FBI......GL-5
Transfer Case,NV241......AP4
Steering/Brake Fluids
---Power Steering Fluid......AP4
------OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) [4]
---Brake Fluid......HB
------AMSOIL Brake Fluid DOT-3 (BF3SN) [5]
[1] Mopar part no. 04874464 or equivalent
[2] Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPAR Limited Slip Additive
[3] Synthetic based oil.
[4] ATF+4® Automatic Transmission Fluid
[5] Hydraulic Brake Fluid, DOT 3
P/N 04318080AB or 04318081AB, meeting MS-4574
FILTERS:
Oil Filter--Absolute Efficiency Oil Filter (EA15K51) [1]
Oil Filter--WIX 51348 Oil Filter [2]
[1] Replaces the Ea15k33, which will still work for this vehicle
[2] Spin-on Filter
NGK PLUGS AND WIRESETS:
GPSERIES PLUG ----------------- LZTR5AGP
IXIRIDIUM PLUG ----------------- LZTR5AIX-13
PREMIUM PLATINUM PLUG ------ PLZTR5A-13
VPOWER PLUG ------------------- LZTR5A-13
WIRESET ------------------------- RC-CRX067
WIPER BLADES:
Blade Class------Driver____Passenger____Rear
ExactFit T151 T151 T12E
NeoForm T16140 T16140
Winter T37150 T37150
CHASSIS LUBRICATION:
4WD
5-20 Fittings, 0 Plugs..........LM
RWD
7-8 Fittings, 0 Plugs..........LM
CAPACITIES:
Engine, with filter.....................................................6 quarts [1]
Cooling System, Initial Fill.........................................12.7 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 42RLE Initial Fill....................4 quarts
Automatic Transmission, Total Fill 4 speed 42RLE.........8.8 quarts
Manual Transmission, NSG370 (6-SPD).......................3.2 pints
Differential, With 198 RBI With T Rear.........................3.8 pints
Differential, With 226 RBI With T Rear.........................4.6 pints
Differential, With 186 FBI Front..................................2.1 pints
Differential, With 216 FBI Front..................................2.7 pints
Differential, With 198 RBI W/O Rear............................3.8 pints
Differential, With 226 RBI W/O Rear............................4.6 pints
Transfer Case, NV241................................................4.2 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....20 ft/lbs
Manual Transmission
Fill Plug 22 ft/lbs
Drain Plug 22 ft/lbs
Transfer Case
Fill Plug 15-25 ft/lbs
Drain Plug 15-25 ft/lbs
