darkknight1999's Build thread
Looks very nice! What are those two things protruding out to begin with?
As DA stated those are just the factory visor catch mounts ;)
You have some serious skills. :thumb: Any chance of getting a pick with your CB and Radio installed in you dash?
Thanks man :) Sadly I honestly haven't finished it yet… hopefully I can get that done next weekend. I have to take the whole dash apart and reform the windshield defroster tube. I've honestly been both slow in doing that because its going to take a whole day or more… and work has had me pretty busy since the weather finally got better. I have to be careful not to melt the wires in the dash when I heat the tube up.
The build looks great so far! Thank you for sharing.
Thanks dude :beer:
I'm sorta off work today, working from the house but I'm going to try and take a few hours to get the wiring done. But I doubt I'll get it all done.
MR.Ty
Token East Coast Guy
Alright. Best of luck to you, can't wait to see the finished project! :rock::rock::rock:
Well I got the fuse/relay box all wired up but I didn't have time to install it yet.
Sent from my NSA monitoring device... Using the WAYALIFE mobile app
Well I got the relay and switch pod mounted in the Jeep this evening. I'm pretty happy with the way it came out.
Course I had to go and talk to Paul today and now I think I'll make another one but add a gauge or 2... lol
I wanted to use the firewall water tight connector… but it's pretty big… and I couldn't find a place where I could drill a hole that big, so I skipped it. Maybe I'll revisit that again later.
Installed the new Optima battery, battery isolation relays for both the secondary fuse/relay block and winch and the 100A circuit breaker for the secondary fuse/relay block.
Who is Hannah? :)
What is on your hood?
Looks great John! :thumbup:
Hannah's my daughter. ;)
There's nothing extra on my hood... It's stock... For now ;) lol
Thanks Paul!
Well I got the rest of the install done today.
As a quick recap as to what I used for this:
1 - Cooper Bussman MINI FUSE AND MICRO RELAY RTMR PANEL BUSSMANN 15303-2-2-4 http://www.waytekwire.com/wps/myportal/en/products/!ut/p/b1/04_Sj9CPykssy0xPLMnMz0vMAfGjzOJdfSwDPbzdDQ3cA3yNDDy93F3NDB29DQ38DYAKIoEKDHAARwNC-sP1o_AqMTCEKsBjhZ9Hfm6qfiTQJeY4zQk2BVpFQEFBboRBlkmaJwBRbctZ/
1 - MOUNTING BRACKET ATO / ATC & RTMR FUSE BLOCKS http://www.waytekwire.com/wps/myportal/en/products/!ut/p/b1/04_Sj9CPykssy0xPLMnMz0vMAfGjzOJdfSwDPbzdDQ3cA3yNDDy93F3NDB29DQ38DYAKIoEKDHAARwNC-sP1o_AqMTCEKsBjhZ9Hfm6qfiTQJeY4zQk2BVpFQEFBboRBlkmaJwBRbctZ/
5 - SONG CHUAN ISO 280 MICRO RELAY 20A/15A AMP 24V SPDT RESISTOR http://www.waytekwire.com/wps/myportal/en/products/!ut/p/b1/04_Sj9CPykssy0xPLMnMz0vMAfGjzOJdfSwDPbzdDQ3cA3yNDDy93F3NDB29DQ38DYAKIoEKDHAARwNC-sP1o_AqMTCEKsBjhZ9Hfm6qfiTQJeY4zQk2BVpFQEFBboRBlkmaJwBRbctZ/
2 - 10 A MINI CIRCUIT BREAKER 28V TYPE III BUSSMANN 23310-00 http://www.waytekwire.com/wps/myportal/en/products/!ut/p/b1/04_Sj9CPykssy0xPLMnMz0vMAfGjzOJdfSwDPbzdDQ3cA3yNDDy93F3NDB29DQ38DYAKIoEKDHAARwNC-sP1o_AqMTCEKsBjhZ9Hfm6qfiTQJeY4zQk2BVpFQEFBboRBlkmaJwBRbctZ/
6 - 15 A MINI CIRCUIT BREAKER 28V TYPE III BUSSMANN 23315-00 http://www.waytekwire.com/wps/myportal/en/products/!ut/p/b1/04_Sj9CPykssy0xPLMnMz0vMAfGjzOJdfSwDPbzdDQ3cA3yNDDy93F3NDB29DQ38DYAKIoEKDHAARwNC-sP1o_AqMTCEKsBjhZ9Hfm6qfiTQJeY4zQk2BVpFQEFBboRBlkmaJwBRbctZ/
1 - 20 A MINI CIRCUIT BREAKER 28V TYPE III BUSSMANN 23320-00 http://www.waytekwire.com/wps/myportal/en/products/!ut/p/b1/04_Sj9CPykssy0xPLMnMz0vMAfGjzOJdfSwDPbzdDQ3cA3yNDDy93F3NDB29DQ38DYAKIoEKDHAARwNC-sP1o_AqMTCEKsBjhZ9Hfm6qfiTQJeY4zQk2BVpFQEFBboRBlkmaJwBRbctZ/
1 - 30 A MINI CIRCUIT BREAKER 28 V TYPE III BUSSMANN 23330-00 http://www.waytekwire.com/wps/myportal/en/products/!ut/p/b1/04_Sj9CPykssy0xPLMnMz0vMAfGjzOJdfSwDPbzdDQ3cA3yNDDy93F3NDB29DQ38DYAKIoEKDHAARwNC-sP1o_AqMTCEKsBjhZ9Hfm6qfiTQJeY4zQk2BVpFQEFBboRBlkmaJwBRbctZ/
2 - Power Relay Contactor 12v 100A SPNO WHITE-RODGERS 120-901 http://www.waytekwire.com/wps/myportal/en/products/!ut/p/b1/04_Sj9CPykssy0xPLMnMz0vMAfGjzOJdfSwDPbzdDQ3cA3yNDDy93F3NDB29DQ38DYAKIoEKDHAARwNC-sP1o_AqMTCEKsBjhZ9Hfm6qfiTQJeY4zQk2BVpFQEFBboRBlkmaJwBRbctZ/
1 - STINGER SCBM100 100 Amp Marine Circuit Breaker http://www.amazon.com/STINGER-SCBM100-Marine-Circuit-Breaker/dp/B002LARRTE/ref=sr_1_2?ie=UTF8&qid=1404693251&sr=8-2&keywords=Stinger+100A+marine+circuit+breaker
10 - Differnet color 16 gauge primary wire http://www.parts-express.com/search.aspx?N=4294967118+4294963782&Nrs=collection%28%29%2Frecord%5Bendeca%3Amatches%28.%2C%22P_PortalID%22%2C%221%22%29+and+endeca%3Amatches%28.%2C%22P_Searchable%22%2C%221%22%29%5D&Ntt=16gauge*+Primary*+wire*&PortalID=1
3 - s different sizes of Expandable Braided Sleeving http://www.parts-express.com/cat/expandable-braided-sleeving/2193
5 - Sizes of heat shrink tubing - I prefer adhesive lined heat shrink. You should be looking to get the 4:1 shrinking or more. This will allow you space to do what you need to do while still shrinking down around the wiring to form a water tight seal. (1/4", 1/2", 3/4", 1"and if you have anything larger than a piece of 2")http://www.waytekwire.com/wps/myportal/en/products/!ut/p/b1/04_Sj9CPykssy0xPLMnMz0vMAfGjzOJdfSwDPbzdDQ3cA3yNDDy93F3NDB29DQ38DYAKIoEKDHAARwNC-sP1o_AqMTCEKsBjhZ9Hfm6qfiTQJeY4zQk2BVpFQEFBboRBlkmaJwBRbctZ/
1 - 10 Pack DELPHI PACKARD WPK-2-16-14-10PK - WeatherPack 2 Pin Kit 16-14 AWG http://www.performanceplusconnection.com/Item/WPK_2_16_14_10PK
1 - Delphi Packard GM Weather Pack Crimping Tool Kit http://www.performanceplusconnection.com/Item/Weather_Pack_Crimping_Tool_Kit
1 - Delphi Weatherpack / Metri-pack 280 Cavity Plugs 25 pack http://www.performanceplusconnection.com/Item/15324928_12010300_25
25' - KnuKonceptz Kolossus Fleks Blue 4/0 Gauge Power/Ground Wire http://www.knukonceptz.com/mobile-audio/power-wire/kolossus-fleks-kable/sp/kolossus-fleks-blue-40-gauge-powerground-wire/
10' - KnuKonceptz Kolossus Fleks Black 4/0 Gauge Power/Ground Wirehttp://www.knukonceptz.com/mobile-audio/power-wire/kolossus-fleks-kable/sp/kolossus-fleks-black-40-gauge-powerground-wire/
Of course there are the battery terminals, ring terminals, electrical tape and so on... but this should get everyone going... if you have questions PM me and I'll give you my number and email and we can figure out what you need that way.
Oh and as for the switches and the spod I made... if you need help with either building one yourself I'll be doing a complete "how-to" over the next 2 weeks or so. So stay tuned ;)
liljohn850
Thanks for making my handy work look all ghetto :cheesy:
I thought I did so well on Travis' (Da Runt) connectors too :rolleyes2:
Seriously looking good! Get those tires mounted!!
Thank man!
Tires should be here Tuesday but I need to buy and install my lift and trim my fenders down.
So assuming the weather is good, I'll trim the fenders this upcoming weekend. Then once I get the ready hopefully I'll have put enough money away to buy my lift.
I have a few switch pods to make, so I'm hoping to get those done this week as well, if all the parts show up.
liljohn850
Thank man!
Busy busy man!!
Looks like Brown Santa made a stop at my house today :D
Geez... Who wants to be home!!! This guy!! :D
