DP1120
Thank you. Honestly, I could skip the $1300 on gears, and spend it somewhere else. It is acceptable with 4.10, on these tires. We are going to be pulling an R-Pod camper, that weighs about 2650 pounds, empty. That's the reason for the gear change, at this time.
I understand completely. We will be pulling something very similar and will go to a 4.88 gear once i get enough for the 35's for mine. I seem to have too many hobbies that cut into jeep money for some reason from time to time. I am debating gearing mine though as it has the 30 front and i know eventually it will be changed to at least a PR44. Havent decided if i should just go ahead and gear it and try to sell it later to someone that is in need of it or just deal with the 3.73 until i swap axles.
