CARNAGE!! Let's See Your Best Breaks & Trail Damage
mojavedave
I see what you mean no there Jeff!
My damage is nothing compared to some of the pictures I've seen, but I've only been wheeling for about 3 years now so give it time! It will happen!
Pulled the fender and flare up, fixed a dimple on the bottom leading edge of the fender, and used a heat gun on the flare, good as new.
BTW this happened at Calico trying to do No Left Turn.
Yes, Jeff, you DID fix it up pretty well! LOL
Dave
g4willy
Don't forget to disconnect your quick disconnects when using electronic sway bar disco. Kane Creek. Thanks to the crew at the Outpost for straightening and the tack weld!
Cheap fenders and water/mud don't mix. Rampart Range
Bent rear axle has adverse effects on your carrier and axle shafts
JoseRubicon
Not nearly as bad as you guys. But compliments of Rausch Creek Off Road Park. I got stuck balancing on a rock and didn't realize passenger tire would hit a rock when turning my steering back and fourth.
A little help from winch and a buddy and got out. ImageUploadedByWAYALIFE1425128557.768311.jpg
xwaz
My damage is nothing compared to most of yours but this is everything from moab and today on ironclad
