has anyone wired up there lockers and ARB air compressor to DIY Spod, im about to order my arb air compresssor and i already have cool switches and dont want the crappy arb ones!!! reason i ask is beacuse the arb wire harness has a ton of wires and my switches only look like this View attachment 86404
the ARB locker switch has more connectors on the back of it and it comes with your locker when you order it so you dont need to order new ones. you can always switch your cool rocker cover over to the connector.
I dont wana run there switches as they dont allow you to run the lockers in a selectable use! Aka like rubicon lockers!
huh? how wouldnt they? :hmm: to turn your locker on you turn on your air compressor then hit the switch for what locker you want engaged. so compressor and rear, or compressor and front, or compressor and both. ARB's are selectable.:yup:
^ their switch bodies would still allow you to engage the lockers anytime the compressor is on, and the key is on. Unlike rubi lockers.
but as long as the Carling switch body styles are the same, you can switch the covers and use the ones you already have.
Looks good!
Yea, I finally got mine to fit by grinding plastic off the backside. Daystar has some work to do.:naw::naw:
The metal clips from earlier JK s do not work either.
Where did you grind the plastic off? I've tried double sided tape and not even that worked to keep the panel in place. Problem is the original piece used 4 clips whereas the Daystar only uses 2. They really need to include some metal clips that work in the kit, even if it means charging a little bit more. Every time it pops out I get more and more frustrated.
Nice work darkknight! please post up more pics when you get a chance! :thumb:
You could probably steal some of the metal clips off of the black plastic cover on the inside of the tailgate. It has quite a few and won't miss one or two. Pry that off from the bottom first. The top has tabs that will break if you pull top and bottom at the same time. I only know that because I used the Rugged Ridge A-Pillar pod and the instructions include stealing one of the metal clips from there. Pissed me off that they didn't just include it with the kit, but it seemed to work out just fine.
