Fender Flare Poll…because who doesn't love a poll
Fender Flare Choice
  • Nemesis Notorious
    Votes: 13 22.4%
  • Poison Spyder Crusher
    Votes: 27 46.6%
  • Bushwacker Flats
    Votes: 18 31.0%
  • Total voters
    58
Bootman83
Just a few more from the evening hours, or AM depending on where u are.
Bootman83
Here are a few from this AM w/camera phone.
cozdude
Guy with a Red 2-Door
Hahaha your post was funny! Glad you were able to get it done! It looks really good! This is on my list as well when I decide to do the 35's
Sent from my iPhone
OverlanderJK
Resident Smartass
That was way to much to read but it seriously took you 12 hours? Damn!
Next time just cut and don't measure. It can't turn out too bad. :thumb:
Bootman83
Haha, yeah…Well 11 if you want to get technical, give me an hour for dinner. Not sure if they'll be a next time…but I do have the rear to do. So we'll see.
Sent from my iPhone
Thanks! Yeah, I'm happy to have got it done. I was worried about the gap making my tires look small. I think its proportional tho and like it.
OverlanderJK
Resident Smartass
That was only the fronts? Man I feel bad for you. That's dedication! I would have given up after a few hours. Or ran no fenders. Lol.
(It took me 3 weeks to install my lift so don't feel bad. :thumb)
Bootman83
Haha. Yeah. I was hell bent on finishing it. Most of the delay was not having the right tool for the job to start. But I did exchange that 80 dollar cordless dremel for the 40 dollar corded one today. So when I dive into doing the backs it shouldn't be as bad. Plus I don't think the back has that damn substructure which took me an additional hour to get thru bc I used a handsaw for most of it. Haha.
Dude by far a jigsaw is the easiest fastest cut I believe. Would have saved you a ton of time. Just follow the straight line of the tape. Use a light sand paper to clean the edges. But regardless. They look good man. Nice job. Now on to the rears. Good luck man.
OverlanderJK
Resident Smartass
I used a jig saw with no tape. Pretty easy and came out nice. Used a belt sander to clean the edges and then put the door trim on to make it cleaner.
I've done it both ways, with a jig saw and with a dremel. The prior will be a lot faster and the later will give you more precision cuts. If you belt sand afterwards, a jig saw would be fine to use.
Bootman83
Yeah. This whole thing is new to me so I just went with the dremel since I thought it'd be the most precise. I don't have a ton of power tools and didn't want to spend 500 bucks to get a crap load of tools. Ill definitely be adding to my tools as I go along tho! Def need to work on the rears. I haven't gone out to look closely at them but I believe they should be slightly easier. No substructure no light install. So that right there makes it a bit quicker.
I would use the rubber paint or plasti dip stuff to paint your wheel wells when you pull the liner out. Works great. Added protection. Easy touch up looks good. That's if you hadn't already planned to.
Bootman83
So as I said in a previous post. I drilled a 1/2 hole (for the side marker light) in the wrong hole (fender moulding clip hole) meaning the hole is slightly bigger then the moulding clip. It's not noticeable to anyone except me and if it were an interior hole I wouldn't even care but its the first one by the headlight. There isn't any movement unless I take it and pull the flare away and it just slides right out. So the question is best way to remedy this issue for a tighter fit? I could use silicone? I could just tape behind it (which is how it is now) or if anyone knows maybe use a larger moulding clip (part number if you know)? Ideas?
StrizzyChris
OK I was lazy and didn't read the "I'm in trouble posts, but they look great! Probably my favorite front fender lines that I've seen. Kinda wish I woulda cut mine like that :thumb:
Bootman83
For people who have done the rear. Would you recommend taking the fender flares off or leave them on. There is no substructure but to fight on the rears but there is the liner. So I'm unsure if I should take them off or just slice thru them and cut with them on?
