What lift are you running for the 37s? I'm going to get some here within a year or so and don't wanna lift mine too big. Thinking 3 or 3.5 inch should do the trick with flat fenders haha
Air down put it in the garage and pull the wheels and tires if your worried.Nothing new to the jeep, did order tires for the Subaru finally however so I should have that on the road soon so I can get the jeep in the garage to start fitting the corner skins and make a side plate I can weld to them for the carrier.
Would be it bad to have my tires aired down for a while?
When ever I strip a bolt I usually just weld a tab to it so I can twist it off.
Could you weld a nut to the outside of the bolt and get it out that way?
Love the Daily Driver! Never done it on a JK but on my old Chevy we would undo the body mount blots on one side & use a floor jack and a couple blocks of wood to lift the body up slightly. But if it's the nut inserts that are stripped I don't think that will help. I've had the nut inserts strip on me after already installing the skins & I was able to cut the bolt head off so the skins would come off then tac weld the insert. Good luck!
Another pointless update.
Finally after thinking it would never happened, passed the PA emission test on the Subaru....LEGALLY!!....which was amazing and started to drive that to make sure itll be good for when I tear into the jeep.
Plan is to first get the rocker skins off and sanded down and re painted, even though its cold guess ill just take my time or send them for powder. Then start to install my corner guards. Going to see if my local guy can bend some tube for me for the lower part like evo does in house.
Any tips on jacking up the body slightly on one side so I can get to the rocker skin bolts? All the lower ones are slightly stripped and the sliders are in the way of using a bolt extractor on them yet.
Pic of the "new" daily in my usual picture spot.
getting closer to having it on the road....then to figure out how I can fit my jeep in the garage so I can get some stuff I want done to it...mainly pull the skins and paint them which will be a chore due to all the lower bolt heads being stripped and the cage in the way.
I'm starting a petition to get the jeep back!!!! All in favor vote JEEP!!
