2013rubirick
You need to hit the bottom corner with a 4x4 and hammer. It should bring the front up. The top should be level all the way across. The front is definitely pointing to far down.
Looks about as close as I am going to get, bottom corner sticks out a little.
Does this look right?
I was gonna drill, but the skin seemed too far away from the tailgate
Put a clamp through the tail light hole and on the bottom under the tail light and you may get it a little tighter
This is how I clamped mine. The bottom clamp helped push the end by the door up
I gave up for tonight, need to find more clamps and a friend that can help. Stupid thought tho maybe, when these are released they move a lot, can the nutserts handle this and is it going to be this hard to line up again once they are painted or coated?
This install makes me just wanna comp cut it lol.
Well battery also died so had to run for a new one for tomorrow.
Oh and did this finally
How is the lower decal with the wiper blades and vision? Just curious want to do something similar.
Hmmm, this doesn't look to fun for the corners. I'm moving to aluminum evo corner skins this spring.
Half tempted to just take a dolly an hammer to it to make it perfect.
I keep having this thought that its easier installing on a 4 door since the straps pull different (in my head), well that they line up with the door opening rather than just on the side of the tub.
