benatc1
That's next, kind of. I had to remove all my wiring to my A pillar switches because they wouldn't clear the Cage. I still have to install my SwitchPro, and reconnect everything. It took me a while to do the Cage. Just lots of steps. Like cutting the soft top positioners on each side. I tried using a hack saw. Finally said fuck it and whipped out the Dremel. Chasing the threads took a lot of time. The amount of metal crud I cleaned out told me it was worth it. RH must have used their old taps on my threads. I also had to remove my overhead Tuffy CB mount and the radio. Eddies suggestion to use the KC HiLites mount is genius! This is perfect. It was two weekends for everything. I did the rear overhead plate plus the B Piller brace with the front belt connections and the rear seat belt bar. I figured this would brace the rear factory cage bars. I didn't get the C pillar brace. This would be another weekend I think. Not sure if I'll do this or not, IDK.
I used the Kc clamp for both CB and switch pros panel, worked great for both
