CarolinaJK
Wow! I guess you just gotta take what time you can with it then. It's one of my favorites on here!
The Jeep is looking great and I'm jealous of the Sedona pics! The family and I need to get up there. I recently installed the mini liners too to clean up the look. Maybe complete overkill, but I used the dremel to cut the studs off that point straight down on each side. I was worried about catching the front tires on it. <img src="http://wayalife.com/attachment.php?attachmentid=218108"/>
Looks like the lines may have sat on top of the TB or were rotated under it more before hand.
Disconnected the track bar from the front axle today to fix the steering ran lines and check out the contact between the track bar and passenger fwd upper control arm mount. Definitely a lot of contact going on and something seems off.
I'm no expert, but wouldn't that mean that you castor is off. Wouldn't dialing more positive castor pull that upper arm away from the track bar?
I went out and looked at it again and yeah I think if I shorten the upper arms it'll pull away slightly and give me some clearance. I'll have to dig out my protractor and see what caster angle I have right now.
I'm sure you've see it. But in case you haven't, Eddie's write up on how to do a front end alignment has a section on dialing in castor. If that your problem!
Awesome build dude! I actually just followed you on insta a couple days ago and was thinkin your rig looked like wayalife material.
It's natural I hang out here. It's where all Evo fan boys are. lol
Always fun drilling holes in the body.
