Trail essentials- What tools to Carry Offroad
RedSyndrome
Lots of stuff listed in the original post and then added to by other posters. The only thing I could think of was a spare brake line. I have a spare steel braided line in case I catch one again on something.
Nice list of items. I would take some on some trips and others on different trips. Because of all the weight I empty my Jeep completely after I get home from an off road trip.
Another great idea.
I hear you on "heavy". I've only wheeled one major trip with it all. It did fine but it was heavy!!!!!
ThunderCAT
What about weight...what is a reasonable weight for all this extra gear....I mean how much is too much and when do you worry about a backward rollover when entering at slope if you have a ton of weight in the back end.
ThunderCAT
I tend to make sure I have extra pins for the high lift
I also carry two axes. Been places for dispersed camping and needed a bit more than a saw to fall some dead trees. One for me and the guest... Speeds up the process
I admire you guys that carry extra shafts and u joints... I don't have the skill set to fix stuff on the trail such as welding or replacing u joints... I am learning off YouTube since you can do anything after looking at some vids...
Most of my gear is set up for recovery and easy trail fixes...
Zip ties are amazing in a pinch...the big 175 lbs load ones are awesome.
mo0s3
What tools are in your trail bag ?
I want to create a good trail bag and not overload it with useless crap :)
Peak
Tools
Breaker bar
Knife
Blade
5/16 deep socket for diff covers
Torx Socket set
vice grips
Screw drivers
Socket Set
Ratchet
Extensions for sockets
Socket adapters
Plyers
Crescent Wrench
Needle nose plyers
Allen set
Prybar
Hammer
channel locks
Spark Plug Sockets
Basic Supplies
Food & Water
Flash Light
Fire Extinguisher
Toilet Paper
First Aid Kit
Zip Ties
Gloves
JB Weld
Spill kit
Duct and Electrical Tape
WD-40
bailing wire
Fuses
RTV Gasket maker
Wire
Tire Repair Kit
Tarp
Hand Sanitizer
Wet Wipes
Foldable Shovel
Foldable Tire Wrench
Heat Packs
Blanket
Fire Starter
Ibeprophin
Road Flares
Jumper Cables
Bottle Jack
Quick Steel
Plastic Bags
Spare Parts
Serpentine Belt
Driveshaft
Axle shaft
Coolant
Brake Fluid
Engine Oil
ATF+4
Gear Oil
Power Steering Fluid
Break Lines
Lug Nuts
Wheel Studs
Radiator Stop Leak
Water
Recovery
Tow Strap
Snatch Block
D-Rings
Front & Rear Tow Points
Fuel Container
Tree Saver
Here's the list Im aiming for, i have about 75% so far.
mo0s3
Tools
Breaker bar
Knife
Blade
Torx Socket set
vice grips
Screw drivers
Socket Set
Ratchet
Socket adapters
Plyers
Crescent Wrench
Needle nose plyers
Allen set
Prybar
Hammer
channel locks
Spark Plug Sockets
Basic Supplies
Food & Water
Flash Light
Fire Extinguisher
Toilet Paper
First Aid Kit
Zip Ties
Gloves
JB Weld
Spill kit
WD-40
bailing wire
Fuses
RTV Gasket maker
Wire
Tire Repair Kit
Tarp
Hand Sanitizer
Wet Wipes
Foldable Shovel
Heat Packs
Blanket
Fire Starter
Ibeprophin
Road Flares
Jumper Cables
Bottle Jack
Quick Steel
Plastic Bags
Spare Parts
Serpentine Belt
Driveshaft
Axle shaft
Coolant
Brake Fluid
Engine Oil
ATF+4
Gear Oil
Break Lines
Lug Nuts
Wheel Studs
Radiator Stop Leak
Water
Recovery
Tow Strap
Snatch Block
D-Rings
Fuel Container
Tree Saver
That's awesome, thanks for taking time to type that up !!!!
gurjeezy
You might want to do a search if you haven't. There are several threads addressing this with some great information and ideas.
Thanks for those links.
OP I was going to reply on this thread but will reply on one of the links CCTX50 posted for the sake of organization.
gurjeezy
Don't forget the bolt extractor kits for stripped or broken bolts.
• Screw extractor bits
• Center punch
• Center drill bit
• Hammer on bolt extractor sockets
holliewood61
I always throw the hammock and sleeping bag in when I go. You never know when you're gonna break bad enough to spend the night on the trail. Ask me how i know.
