The Build and Adventures of Bearbait
Installed my front EVO Plush Ride coils today. Jason0311 was nice enough to open up his garage to me so I didn’t have to lay in the snow to install these.
The ride is so much smoother! Definitely a quality upgrade. I purposefully hit some potholes I know to be jarring and these coils soaked them up nicely
Hopefully I can get the rear coils sooner than later!
Real men lay in the snow...so says the guy staring at palm trees out the window
Nice! Are they 3” coils?
They are the 4 inch, I used to have 3.5 inch coils and a half inch spacer
Looks good, what did you remove? Curious how much lift the 3” springs give a 4 door, did you measure by that illustration?
I thought about measuring, but unfortunately I forgot... I pulled out metalcloaks 3.5 dual rate coils and a half inch spacer. Those coils did sit higher like 4 inch coils. So the switch didn’t really change my ride height..
Hahahaha I would’ve if I didn’t have the option!
Well Bearbait has received its first windshield crack... not certain how it even happened, just showed up yesterday morning. Maybe had something to do with the low being below 0? Not a clue
.. not certain how it even happened,....Maybe had something to do with the low being below 0?
Likely. Very common. Happens here in CO too as the temps rise and fall to extremes. If you haven't already, you may want to check with your insurance company for glass coverage. I think ours is like 4 dollars extra per month. Covers repairs and replacements, Zero dollar deductible, and no matter how many glass claims, the rates don't go up. And glass guys are mobile now and come to wherever you're at.
I’ve had it done years ago to a Ford Explorer, but I’ve changed since then... thanks for that reminder!
My first crack on Brute started as a small chip from a rock thrown from a truck in Boise at 500 am, 38 degrees...by the time I got to Salt Lake City, it was 70 degrees and a crack spread across the windshield...I'm now on my third windshield
That’s crazy! Didn’t realize it would spread that fast. I knew it would happen eventually but had high hopes lol
I got my first one back in spring while bringing a buddy to the airport, worst part was it was thrown from the tire on a Prius...
No good deed goes unpunished.
Just doing a little dreaming today :crazyeyes:
MY DREAM BUILD LIST
EVO long arms $2,964
EVO Double Throw Down $3,811
EVO lever $5,432
EVO corners $326
EVO Rockskins $290
EVO Sport cage $1995
EVO Tire Carrier $1318
EVO rear fascia $229
Pro Rock 60/80 5.38gears $17,995
Chamber Pro 2 $2000
Adams 1350 driveshafts $1379
LS engine swap $22,794
40inch STT Pros $2230
Hydro assist $2669
Half doors $1429
Mastercraft baja rs seats $1000
Atlas transfer case $3070
Cobra 29 Ltd bt cb radio $151
Rubicon sway bar disconnect $1434
Maybe I’ll start a go fund me lol
MY DREAM BUILD LIST
EVO lever $5,432
EVO corners $326
EVO Rockskins $290
Chamber Pro 2 $2000
Hydro assist $2669
Half doors $1429
The cb looks affordable!
