Orion
TrailHunter
Awesome views [emoji41]
They really are. Pictures never do justice either...
Looks like an awesome trip! What kind of tailgate table is that? I need one!
M-Pac Springtale... very happy with it’s simplicity and quality. Perfect for lightweight cooking and prep needs. If you need something stronger... look at EVO’s.
That came out great!
Thank you! Can’t wait to see them out of the garage and on the Jeep.
Jsouder53
Awesome! I’ll have to look into those! And I’m sure you’re ready to have them on your jeep [emoji106] what size tires are you going with?
Jsouder53
Since I’m having so much fun on stockers... I want to see how far I can push 35’s before stepping up to 37’s.
Definitely! I love my 35s but absolutely want 37s eventually, I just like the way 37s look on a JKU and knowing I could take on more obstacles or trails... then again 35s will get me down pretty much 99% of the trails in my area [emoji23] so really my only reason for 37s would be looks
Orion is a little over a Year old now and we revisited his first trail... While at our family trip to Bass Lake.. the wife and I took a relaxing ride through the mountains at 6:00am this morning... We were back on the Lake by 9:30. By no means a hard trail, but some great scenery.
There are miles of off shoots and other Trails in the area... but time was limited... Can’t wait to do more exploring there.
Man, I haven't been up there in years. Nice to see you got out and had a great time :thumb:
black pearl
Stopped to make some Coffee and check out the Lake View.
Found these Gems among some rustic cabins.
There are some large rock formations to play on.
Along the 20 mile trail there are awesome little creeks & meadows..
Awesome! 🤙 looks like a great trip. Jeep is looking good!!
I want to explore that area a little more when it's not covered in snow.
TrailHunter
Finally got some time to wrench on Orion:
Added 3/4 spacers up front to get rid of the Soccer mom Rake. Maybe I’ll need the rears later.
Got C- Gussets welded in. Don’t judge my ugly welds... it’ll hold. [emoji51]
All painted up, spacers in and reassembled.
Surprisingly if you measure the body lines, there is still a +\- 1” rake.
Not sure if I’m supposed to get it aligned.... it drives fine.
JKbrick
Looks good, if you didn’t mess with the tie rod you don’t need alignment, but if your steering wheel is slightly off you can just adjust the drag link
TrailHunter
Jsouder53
It’s looking good! You were able to weld the c gussets on with everything still intact? That’s awesome [emoji106]
TrailHunter
Yeah, it was easy with the springs out.... and I just took my time letting it cool off between sections.
There's nothing to align on a solid axle. The small spacer shouldn't affect your caster enough to be an issue and you don't have adjustable arms anyway.
Good point... thanks bro.
Jsouder53
That’s awesome! I still have yet to install mine... just sitting in my shed [emoji23] I don’t know anyone who has a welder or anyone that knows how to
sipafz
The welds look good to me. They look pretty “flat” so I’m sure you got some decent penetration.
Back when I made my budget boost, I ended up with 1.5” more spacer in the front than the rear to get level. Part of that is that I have a 100lbs of winch to offset.
Being that you only added 3/4” you shouldn’t need to worry about bump stop extensions or shock extensions. Just another thing to consider if you end up adding more someday.
Bear_JT
That all came out looking good. Good job on the C Gussets.
TrailHunter
Thanks... Hopefully adding the 3” lift & 35’s next year... so figured I’d just throw some spacers in while installing the gussets. I bet just the 1/4 pounder alone brought the front down a bit.. so I could be only a 1/2” or so higher than stock... that’s nothin really.
Those welds look pretty good.
Did you do anything to keep the ball joints cool? Did you check them to make sure they're still OK?
Sent from my SM-G900V using WAYALIFE mobile app
Thanks. To prevent damage I just went slow... small section at a time... then held a cool wet rag over the ball joint repeatedly dipping it in a bucket of water... Not really sure the rag made a difference & didn’t want to hit fresh welds with cool water. The upper ball gets the most heat because the welds are so close.... I was kind of worried about the axle seals as well... going slow is key. I did not check anything.. but knowing me, I’ll probably be installing Dynatrac ball joints before the lift anyway.
