Ddays
I've build miles of fence and never knew such a thing existed. Does it just drive the peeler cord straight into the ground? We use an auger or pneumatic post pounder to drive metal pipe post or t-post into the ground.
Yup, one of the best things ever invented! We used 8" dia posts for the corners and 5" dia for all the others. You adjust the driver for both axes so that its perfectly straight, raise the slide with weights welded on it (hydraulically) and once at the top, release the lever and it pounds the post in. It is fricking awesome! It took about 20-25 strikes for the 5" posts and 40 or so for the 8" ones to drive them 3' down. It really helps that the ground is pretty damp. Sure as hell beats using an auger and tamping all of those damn things in.
