2014 electronic stability control light on after installing PSC Big Bore XD2
mondricek
So i installed the PSC SK285 kit last weekend, now my ESC light (burnout swigly lines) are on. My horn and volume controls work. I’m getting a C123F code. Steering wheel corrected. Does anyone know what’s causing the code?
If your steering wheel is for sure centered, could be you damaged your clock spring during the install.
Did you secure your steering wheel prior to removing the OEM steering gear. If not the wheel was spun one direction or the other and the Jeep thinks you are in a turn.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
2015 JKUR AEV JK350
1985 CJ8 Scrambler
I secured the steering wheel with a ratchet strap, but honestly idk because I was changing out the radiator at the same time so idk if I ratchet strapped the steering wheel with the wheels straight or not
If your wheels were straight when you locked it down, you should be good. Is you steering wheel straight while your driving? If it’s off a little, it can activate the ESP too.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Unfortunately, I agree with Eddie. I think your Clockspring is screwed up. Time to take it in.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
