nmwranglerx
Sweeet, have fun with swap. I did mine in my driveway few months ago. Took our time so whole day affair even for one axle.
I do have changed the switch setup. These two switches are safety switch. So in order to turn the lockers on, I have to put those two switches on, and then with my ORE switch panel, I activate the lockers seperately. It's only a matter of security. I don't want to accidentaly put the lockers on while driving at speed.
A Sahara with a 3" lift and 35's and stock axles will still perform nicely offroad!
Oh yah, I am always impressed with the off road capability of these vehicles!! Frankly the only reason I got the axles was because I was contemplating a regear to 5:13s when jumping up to the 35" tires and I was able to pick these up already outfitted with the 5:13 installed!
I bought rubi harness, cut connectors off with about 8" wire left on them. I spliced them to 16 gauge wire and ran wire along the passenger side of jeep inside wire loom and ziptied to factory loom. I already had a lower daystar panel installed, so I bought arb style switch and wired into that. Holeshot shared some wiring advice, so I wired man similar with lower light as on/off indicator
Nice! I have lockers but try not to use them...I kinda like to think of them as insurance if I get in a jam. Makes obstacles more fun without them sometimes!
... my wife has no idea that her soon to be newly cover patio in the back is about to be converted into an axle shop. This is hilarious! Sounds all too familiar. Much easier to beg for forgiveness a wise man once said.
... Did the C's come already gusseted? While you have em in the "shop" it would be a bit easier install.
Right!?
Nope, but I was looking at another build and thinking that I might as well pick up a set and weld them in while it's sitting in the garage before installing... (not sure that my welder or my skills are up to the task) I sense a little welding get together coming
I was thinking the same thing. Considering using the same switches but placing next to them a covered safety switch that would need to be on to activated the two rocker switches.
So it you are using these two on the left side of dash, where are your diff on/off switches? A couple more pics maybe?
Here's a thread that talks about factory locker wiring.
http://wayalife.com/showthread.php?...Locker-Wiring&highlight=factory+locker+wiring
I posted my wiring diagram on that thread, but added ORE switch panel later.
Switch or not...
I bought my 2007 JKU Sahara not knowing anything about Jeeps except that I've wanted one most of my life...
My recent build-up; I found a heavily reinforced (double gusseted, externally clad and trussed) Rubicon D-44 housing (empty) ...
The outcome is very capable, I spent the last two weeks breaking in my new axle/gears in the Rimrock/Nile area of Washington. My Jeep is very capable even with only one locker in the front. My rear remains stock except for the gears and is next on my list to upgrade, which will include a similar setup, 35 Spline ARB, 35 spline G2 axles and a new rear driveshaft to make my drivetrain as tough as you can get in D-44's. The only addition beyond that may be a Rubicrawler to get me even lower for climbing and decents on the steeps. :thumb:
You can see more about our Jeep (Julia) at www.Livin4Today.com![]()
Any updates on the swap?
Here are my on/off switches.
View attachment 43687View attachment 43688
