Some lessons are harder than others. Hopefully just your brakes, but you learned how to pull your axle shafts.
ok guys with the amount of threads i have started about question im hoping i don't have to start a new thread to have this question answered.
this past weekend i pulled the axles from my jeep 1 at a time. so i tilted the rear axle so that i could eliminate the amount of oil i lost. i didn't loose much, but i would like to top off. i changed the Diff fluid about 2,000-3,000 miles ago with synthetic, however i don't remember the actual specs on it.
my question is, should i just top off with any synthetic; and is it ok to mix fluids as long as they are the same weight?
or would it be a better idea to drain it and change completely?
It's not a big deal. I have mixed before when I needed to change on the trails and haven't had any issues.
Thank Overlander. just to make sure though, any Synthetic will do?
Got a great deal on Amazon for a CB radio. i got the Cobra 29 LTD BT. so i guess i will find out how this Blue Tooth technology works out.
Outstanding! That's the CB I'm getting this month. Let me know what you think. And, if you don't mind me asking, what mount did you use? I planned on mounting mine to the dash but still not convinced it's better than mounting above.
Sorry it's taken longer to get this photo. Here is a photo of my mount I made.
Drilled 2 1/4 holes in the mounting bracket and Just got some J hooks or whatever they are called from Home Depot. Cut about 2 inches off them added a washed to each side and tightened it up. If you/anyone have any question about it just let me know. It's working really well and has kept everything tight.
Thanks for the photo. I think I'll try that. I wondering how those j hooks don't move around or slide.
honestly im not sure how it doesn't either. but it works well for me. just got to make sure its all tight.
