Lots of people have them. What info are you looking for?
More so whats the time frame between rebuilding them. I.e would it be the same time frame for other ball joints to need replacement. And is the rebuilding something that can be done in my garage, or does it have to be sent out. Thanks guys.
I have over 60,000 miles on my ProSteers and have yet to find a need to rebuild them. I ran them on my factory axle first, put about 45,000 miles on them and then installed and have been running them on my PR44. During the swap, I made sure to check them just to see what if any wear there was and they still worked like new. Because of the way they are designed, I don't foresee a need to rebuild them for a long time to come. IF you ever find the need to rebuild them, you can do this at home in your garage.
Yeah- but do you even wheel it??
Haha
Does the mall count? :idontknow:
It depends how fast you hit the speed bumps!
But in all seriousness, 60,000 miles of hard use is quite impressive! And they're still in good shape... I'm quite curious to see how many miles you get before they need rebuilt.
Check them out first. But i think you will find them blown. If they have lasted so many miles they have done their job. Time for new ones. :yup:Just passed 95k stock ball joints. have ran 35's and wheeled its whole life. Guess I should be in the market for new ones.
:thumb::thumb::thumb:Just finished the ball joint replacement over the weekend. Went well I have to say. Just took patience, muscle and the right tools. The rentals from Advance Auto pressed the new ones in perfectly.
I did try the alignment on my own, but just don't trust my accuracy with it. Getting a slight flighty feel at times and the steering wheel is slightly off center. I'm going to bring it for alignment Monday.
Thank you all for your input!
Ok I have been but maybe I'm not checking Jen correctly.
