MedixJK
IMO this is just a touch too low. You really want at least 3.5" of (actual) lift with 37s. Otherwise you will be driving very close to the required bumpstops. However, can it be done.... Yes.
hinrich did for a bit when he was on his teraflex 2.5". the only thing is since he has a 2 door he yeilded more like 3.25" out of those springs. if you do run that set up you might just need longer bump stops to help prevent rubbing at full flex.
Im running 3" bump extensions because they sent me the taller ones so that may help out a bit. Its obviously not a cheap jump so im trying to sift through what i NEED vs what i WANT....so what about wheel width? i know manufacturers have recommendations, but ive also read on here that a narrower wheel will keep a bead better when aired down. So does/has anybody run 37x12.50 on a factory 17x7.5 wheel? I like the wheels so ive just been running 1.5" spacers.
