This is very true. The guys im referring to wheel much harder than I plan to and seem fine.
thats what i said...
That link he posted with the "PR60 Semi Float" is a Trail60 with the PR60 housing upgrade. Po-ta-toe/ po-ta-to, they are same thing.
it kind sounds like you have your mind made up already! good luck!
He was running 37" Falkens when he broke in Colorado but yeah, he's got a v8.
I have the Dynatrac Trail 60 with upgraded PR60 housing... aka the ProRock60 semi float.
1) Why are you going extended width to 68.5"? Unless you are going to a 1 ton in front also (in which case you should go FF rear) don't understand.
2) Where did you find a Currie RJ60 @ that 68.5" for so cheap? Is it the G2 version?
I have never had an issue with my PR60. My best friend has had issues with his RJ60 (mainly cover leaking from what I believe is the axle flexing). I think both are good products, I just always heard great things about Dynatrac from everyone I know who runs them and heard too many bad storied from folks and their Curries. That made the call for me. Back when I had looked they weren't that far apart. I know the only positive on the Currie is the rear trackbar bracket is adjustable height. The Dynatrac you need to change it if you want a raised trackbar height at axle end.
that's funny i haven't looked at them in a bit but i thought they used to call it a trail 60 guess the pr60 semi float sounds better lol.
In no way have I made up my mind yet. Thats why I made this thread.
So just to clarify not trying to be a smartass but did he have the V8 when he broke or no?
I got my quote from a friend who's a distributor for currie and he gave me the price they buy them for.
Once again I cannot afford full float and I want the extended width because I want the added stance. I will probably not go with the extra with If i do a front 44 instead of 60.
There's your answer. You're getting a distributor price vs retail. Have you tried calling NR4x4 to see what they could do the PR for?
I havent yet but I will probably tommorow.
The price for a pr44 front and pr60 rear is around 11,000 where as that same setup for currie is around 8,600 roughly. At that price I could almost get front and rear currie 60s. :hmm:
I was meaning keeping and building your rear 44 and get a front aftermarket 44 like a pr44. That is done a lot on 37s when the rig is wheeled or daily driven.
This is exactly what I would be doing.
you have just heard many people tell you stories of currie breaks, no one called them teraflex just there axle game isnt on the same level as the PR.
he said he did.
That explains it. You need to find a friend who is a distributor for Dynatrac too so you can get a fair comparison
Like others have said though, if you go with a PR44 or a Currie RJ44 front you may be better off just upgrading the shafts in your rear 44 and locking it. I went to the PR60 Semifloat rear just because my buddy who bought my front axle wanted my rear too and rather than regear it to match my new front it was only ~1,500 more to upgrade to a 60. My logic sucks but I sold myself on it that day ;-)
If you compare the two, your rear 44 has a smaller R&P yes. But it is low pinion. The HP rear 60 is stronger but not a ton stronger. Folks can still manage to break them. I would say for sure the bracketry is stronger, shafts are bigger, etc etc on the Dynatrac rear 60 but it is still semifloat and the weak link is bending a shaft. Some days I still wonder why I didnt just go FF when I did it or keep my stock 44. Next time I would do one of the two. Or go in the middle and get a Solid Axle rear HP FF with ARB for $5k. There are tons of options. Just my 2c.
LOL:cheesy: yea your right I havent heard any currie break stories. I definitely agree there game is not the same as Dynatrac but didnt know if an extra 2000 was worth it if your on a budget like me.
They have a Trail 60 that has a standard(ish) D60 housing. Then, they have a PR60 that is still a semi-float but has the clearanced (proprietary) D60 housing. Then The also have a PR60 full float.
So, three types of 60s (not including options)
^^^Pretty sure on all of that.
