I odered it through 4wheelparts belive it or not. I was there when they did the order so I'm pretty sure it was a Dynatrac mix up. I'm not to worried, Dynatrac has a great reputation and will probably resolve it quickly. I'm just a little bummed out because I waited 7 weeks for it to arrive.
So you ordered it from 4wheel parts and you assume it's Dynatracs fault ?I odered it through 4wheelparts belive it or not. I was there when they did the order so I'm pretty sure it was a Dynatrac mix up. I'm not to worried yet, Dynatrac has a great reputation and will probably resolve it quickly. I'm just a little bummed out because I waited 7 weeks for it to arrive.
I ordered it fully assembled minus the outers. 4:56 gears, Eaton E-locker, 30 spline Chromoly Axles, Rebuildable ball joints, Ultimate 44 housing. Gears and lockers installed and cover sealed on with no axle seals installed? or axles shipped.
I vowed a long time ago to never give 4wheelparts another dime. My guess is that it was their screw up, not dynatracs.
I'll update what hapened next week when I find out more.
Eddie, I don't know who supplies Dynatrac with their axle shafts. I didn't ask. It was supposed to be ordered as a complete assembly. Not RCVs.
WHAT 30 spline chromoly axle shafts did you order as in, WHO makes them? This WILL make a difference as to WHAT axle shaft seals get used. When you buy from a VENDOR like 4WheelParts, THEY are the ones who ASSEMBLE the internal components YOU'VE chosen to buy INCLUDING axle shafts, gears, lockers, etc. The ONLY way an axle housing comes completely assembled from Dynatrac is IF you ordered it directly from Dynatrac. YOU did NOT.
Sounds to me like 4WheelParts is feeding you a line of BS and throwing Dynatrac under the bus for their screw up.
