This doesn't look blocked at all....:dont_tell:
Note: found pic online, not mine.
Yup, you're 100% correct and I should have stated that even with the stock carrier the wheel will block one side of the tail lights at an angle.
From behind you can see both of the lights clearly. The holes in the vertical braces also allow the brake lights to be seen through them. I'm sure every guy running this setup has had a cop following them plus passed inspections with them installed. There is
no issue with seeing the brake lights.
As I noted, one accident and 5 months getting the damn thing back to pre-accident condition gets you looking at stuff you normally wouldn't. I installed those lights because I couldn't
find a third brake light solution I liked so I went with one on either side.
Shame on me, I totally missed the sarcasm...
Hit the brakes in the same photo and the lights stand out just fine. Also, if you are following me that closely and I hit the brakes I'm in my second accident...
move back some and the lights show up just fine.
