And I was thinking I only needed to modify the isolator and I run bumperless and have seen the drop hitch flip I'd have to get one if I go that route
Dopey
I run those exact rims with BFG KM2 35x12.5x17 tires. They fix perfectly on the stock carrier. They actually sit over an inch further away from the tailgate.... However if you do any kind of wheeling, I would HIGHLY recommend upgrading the hinge assembly (like a Teraflex / Smittybilt unit) or get a better tire carrier. I ran mine on the stock carrier for a few weeks and it already started to tweak the tailgate. Any kind of hard bumps off-road and I would be quite possibly looking at some expensive damage.
I used 1.5" PVC pipe with a cap jammed into the stock isolators. I can get photos in a little. A 5' section and two caps were about $4 from Lowes.
That would be great to see the pics and that is with 4.5 back spacing...?
Dopey
Yes 4.5" back spacing.
This is a close up of one. I spray painted the PCV black.
This is how far the tire sits back on the stock carrier.
Any rattle or noise from this setup
Dopey
I used two tennis balls at first but I could stand seeing the neon yellow every time I walked up to the Jeep.
None and its been two years since I hung the 35 on there.
