Don't drive it without a stub shaft in the unit bearing, it can come apart and ruin your day.
Typed by my very own fat fingers on my iPad or iPhone.
That was only the case on older Jeeps with non sealed bearings. JKs are sealed, the stub shaft serves no other purpose other than turning the tire.Don't drive it without a stub shaft in the unit bearing, it can come apart and ruin your day.
The bearings are pressed onto the flanged part of the hub. The stub shaft keeps tension on the bearings and keep them from coming off of the flanged part of the hub. Yes, they're sealed bearings, but they can still come apart without a stub shaft.
X2. If that was true early model 2wd JKS would have wheels falling off. But they didn't. And it's the same unit bearing.Not true at all. At least, I have never seen it happen over the last 10 years.
Never mind it'll be sitting on jack stands until I get an outer stub shaft, unit bearing bolts and u joint.
How would it come apart? I've known several people who have driven around like this after an axle break with no issues.
Looks like you accidentally posted two threads.
There's a bunch of replies on this one: https://wayalife.com/showthread.php/47130-Wheel-sitting-on-unit-bearing
** Thread merged, disregard
I've tried searching on this as well. I've heard of people removing a shaft and driving home on the unit bearing. I'd have to remove both shafts, right? My outer stub is wallowed. So need to get a replacement from g2. U joints will be here today and unit bearing bolts tomorrow.
Ideally yes youd want to remove both shafts. Otherwise you risk breaking the side that is still in place. Just a heads up for the thread: the axle nut only serves the purpose of keeping the axle shaft from walking in and out of the splines. It does NOT hold your unit bearing together.I've tried searching on this as well. I've heard of people removing a shaft and driving home on the unit bearing. I'd have to remove both shafts, right? My outer stub is wallowed. So need to get a replacement from g2. U joints will be here today and unit bearing bolts tomorrow.
You can run with just one shaft out. If you're G2 is made for it, I'd highly recommend you run full circle clips on your u-joints to prevent something like this happening again.
