aTX427
I'm working on my rear and having difficulty with the track bar interference with the rear diff. In speaking with Evo, Andrew said to cut off the Dynatrac track bar mount and weld the track bar mount that came with my Bolt on Coilover kit otherwise it will hit the coilover reservoir. This brings the track bar closer to the diff and collides with the diff cover on up travel. Keep in mind I'm using the stock track bar and have the axle centered at ride height and the bump stops centered at full stuff. My thought was to cut the track bar and shift the clearance bend over by 1.5" and weld on a sleave to secure it. Thoughts?
