As most of you know, Cindy and I prefer to run our Jeeps with big tires and with as low of a stance as possible. Of course, in order to do this and with a minimal amount of rubbing, some trimming of the body is required... okay, a LOT of trimming! Even though we had already knocked off a considerable amount to accommodate 37's, it became clear that even more hemming of the seams would be needed, especially after taking Rubicat out on a test run with her new 40x13.50R17 Cooper Discoverer STT Pro tires.
Being that we get people asking us all the time just how much hacking is needed to run 40's and still keep a low stance, I thought it might be helpful to make the following post.
As you can see here, even though the pinch seam and a portion of the body have been trimmed, our new 40" Cooper was still making solid contact with the edge of the fender well and rubbing the paint clean.
Contrary to what so many people seem to think, your rear axle travels in an arc and even though it may not "look" centered under your wheel well at ride height, your tire will travel backwards under full compression. As you can see in this pic, our new 40" Coopers were still making solid contact with the rear pinch seam as well and this in spite of the fact that a considerable amount of it had already been trimmed.
Here's a shot of what the front half of the fender well looks like after being hemmed.
And here's a shot of the rear pinch seam.
A few shots from the driver side.
That ought to do the trick. At least, that's about how much we've had to hack on Moby. Anyway, I hope these pics are helpful to those of you who are wanting to run 40" tires but without having to run a sky high Jeep.
