I actually run this lift and as others have mentioned, it will give you more than 3 inches of lift.
I run the Alpine Arms, not the Arms In the picture. I had a problem in the beginning with instructions. They are very confusing, not very clear and after calling them, the answers I was looking for were not straightforward.
I have 15k miles on this lift and haven’t broken anything. I also DO NOT Wheel it hard like others. The suspension is stiffer than the factory Rubicon suspension. Doesn’t flex as much as other jeeps I’ve seen on Instagram. I got about 4 1/4 inch of total lift before bumpers and winch. Teraflex claimed it would “settle”, that wasn’t the case. I took adding a couple hundred pounds of bumpers and winch to bring it down 1/2 inch.
If I would of done more research before buying it, I would of gone with a lift a little softer although it’s not terribly hard but stiffer than factory.
Good luck with your install.
Sent from my iPhone using
WAYALIFE mobile app
