I am looking to purchase an XD60 to pair with my UD60 rear.  I'm thinking the XD60 spec'd for the Elite Package is perfect combo.  Does anyone have any feedback on if there are other options I should be adding to it?
• ProRock XD60® Front Axle
• Dynatrac exclusive patented ProRock® nodular-iron, high-pinion ProRock XD60® center-section with bearing bores to handle oversize pinion and carrier bearings for elite housing rigidity.
• More ground clearance than any other high pinion axle housing made for 10.1-inch ring-gear diameters.
• 3.75-inch diameter, variable wall thickness, lightweight, chromoly tubing has the highest strength-to-weight ratio compared to any other light-truck axle on the market.
• Dynatrac exclusive Dual-Sump High Volume™ (DSHV) oiling system to ensure the outer pinion bearing is never without lubrication.
• Dynatrac-exclusive U.S.-made forged, double-heat-treated 1550 35-spline and optional 40-spline axleshaft assemblies. These are the best shafts in the industry and are capable of up to 50-degree turning angles. You get complete 35 or optional 40-spline inners and outer shafts with 1550 joints installed.
• The ProRock XD60 is the only axle in the industry specifically engineered with features to complement and support 40-spline shafts.
• Our new 1550 LT® high-strength, lightweight, military-grade, aluminum knuckles are loaded with our latest set of Dynatrac HD BallJoints™ yet. These are the last ball joints you’ll ever need, and are designed with larger stems and bodies for long life and high durability with big tires.
• Dynatrac’s exclusive 1550 LT wheel ends are equipped with our latest 35-spline or optional 40-spline Stub Hub™. Forged 4140, heat-treated, fixed spindles and serviceable wheel bearings support tires up to 44 inches.
• No other 4x4 front axle offers the ease of steering, low scrub radius, effective Ackermann angle and high steering linkage positioning.
• Includes Dynatrac high capacity 13.25-inch brake upgrade with new dual-piston front calipers and vented rotors.
• Includes our latest integrated track bar and ram-assist steering mounting package.
• Includes new HD tie rod, integral steering arm, new Dynatrac DHD™ drag-link sleeve, control arm bushings, CNC laser-cut HD suspension brackets, all professionally welded and installed.
• Includes DynaLoc™ locking hubs. DynaLoc hubs are over 3 times stronger than all other locking hubs on the market.
• Your choice of a ARB Air Locker or Auburn Gear ECTED Max locking differential and 5.38 gears.
