Ball joints
VeruGE*144
I have no experience rebuilding them, and while I don't doubt their quality, the price point for the ball joints and the rebuild kits was a bit higher than I cared to spend right now. Also I don't think I'd be able to tell the difference in new ball joints whether it be oem, synergy, or prosteers. Any new ball joint will be better over my worn ones...[emoji6]
Dynatrac released a video on how to rebuild their ball joints about a month ago.
https://youtu.be/xL4axrsb1k4
jesse3638
It’s easy to rebuild a brand new ball joint. How about ones with 80,000 miles?
Additionally me being a numbers weirdo it would take the initial purchase of Dynatracs and 3 rebuild kits to break even on 5 sets of synergy or crown ball joints. At say 35k per replacement or rebuild that's 140k miles. With my annual mileage that's another 28-35 years...haha.
BaddestCross
I notice on the lower joint has a regular zerk fitting. (Nipple type) Any concern of breaking that off? Could it be replaced by a needle type or flush. Or whatever they are called.
It's angled and inside the C, not on the bottom. The worst part is actually getting the grease gun in there. I finally saw someone talk about using a needle point instead of the special "hard to reach" attachment that was recommended and it's perfect.
jesse3638
Yeah Bubba suggested to make sure it's facing forward so it's easy to access it. He also said it may hit the c and if so I could grind it out a bit. I know what you're talking about using a needle fitting on a regular zerk. I have to do that on the rear u-joint of my rear drive shaft. The regular fitting feels like it goes on bit not quite all the way. I ended up piling a ton of grease all over the joint because I couldn't see it..haha.
BTW what's a good interval to grease them? I do my oil changes every 4k miles would that be sufficient?
BaddestCross
Every oil change should be fine
Seahawkfan
Thanks I think I'm going to go with these when it's time. Keep us up to date on how they hold up. :thumb:
