Ball joints
jesse3638
So which ones did you go with? I might be the market for some soon too.
I ended up going with Synergy ball joints and evo C-gussets. Now will put my welding skills to the test...haha.
I would recommend DynaTrac ProSteer ball joints and Evo C gussets.
I was going to go that route but after hearing how much of a PIA they are to rebuild I opted for synergy. Also the rebuild kit is about 3/4 the cost of synergy's.
rubiDave
Synergy's are knurled though, right. Or do they offer smooth?
Quick question. When pulling the unit bearing does it require a slide hammer like an axle shaft or will it come right out?
Have a slide hammer on hand. The clearance is so tight between the bearing and knuckle that even light rust in there can make it hard to get off.
jesse3638
Thanks! I think I'm just going to buy one of the damn things. I've rented one at least a half dozen times now...haha. Plus I can probably use it to pull my rear lca bolt when I install the rockstar skids.
jdofmemi
Here in SoCal, yours should not be rusted in like in places that have real winters.
Mine came out with a light tap.
Ruvicon
I just pulled both of mine which were rusted badly. I had to use a 7 ton 3 jaw puller and barely got the passenger side off. I had to beat the shit out of it with a BFH before it finally popped loose.
jesse3638
Yeah I'm hoping for the best being that I live in the desert.
I just want to be prepared so I'm not making multiple trips to get parts and tools..haha. Thanks for the heads up.
USMC Wrangler
Mine weren’t bad here in AZ. They needed a couple taps to come free. I did try and muscle them out at first since I had never pulled any axle shafts like this. Tapping with a hammer worked well.
Clearskies
I just did both the Ball Joints and new front axles.. I guess I was lucky because everything went pretty smooth.. Light taps with a hammer where needed and not a lot of rust. I've got 50 k on it but it's only a little over 2 years old. I suppose not a lot of time for the rust to set in.
black pearl
I was completely surprised to find it so loose. I plan on pulling it into the drive way today and going over the whole front end. It was 8pm when I found it last night and was hoping retorquing it would solve it so my step son could drive it to school today. I need to check unit bearings too. Maybe I'll just do unit bearings and ball joints every 36k miles...haha. I was planning on prosteers but after hearing about how much of a PIA they are to rebuild I'll probably look at Crown or Oreilly. With selling the house I was thinking I may be able to do a PR44 when I get new tires and regear the rear in a few months, so I'm not wanting to invest a ton of money.
I must be one of the few that don’t find it bad to rebuild pro steers. The first lower was slow, but once I saw how it went it was really easy after that.
jesse3638
I have no experience rebuilding them, and while I don't doubt their quality, the price point for the ball joints and the rebuild kits was a bit higher than I cared to spend right now. Also I don't think I'd be able to tell the difference in new ball joints whether it be oem, synergy, or prosteers. Any new ball joint will be better over my worn ones...[emoji6]
