BaddestCross
Good news. No contact with the suspension fully compressed.
Congrats on getting it worked out!
[emoji23]
Congrats on getting it worked out! [emoji482]
My factory ball joints went out at 15k. That was with the stock rubicon tires too. So I wouldn’t doubt that’s what needs replacing.
I ended up going with Synergy ball joints and evo C-gussets. Now will put my welding skills to the test...haha.So which ones did you go with? I might be the market for some soon too.
I was going to go that route but after hearing how much of a PIA they are to rebuild I opted for synergy. Also the rebuild kit is about 3/4 the cost of synergy's.I would recommend DynaTrac ProSteer ball joints and Evo C gussets.
Synergy's are knurled though, right. Or do they offer smooth?I ended up going with Synergy ball joints and evo C-gussets. Now will put my welding skills to the test...haha.
Yeah they are knurled. So after I install them any replacements will have to be as well. Hoping to put a PR44 in later this year so we'll see what happens.Synergy's are knurled though, right. Or do they offer smooth?
Quick question. When pulling the unit bearing does it require a slide hammer like an axle shaft or will it come right out?
Thanks! I think I'm just going to buy one of the damn things. I've rented one at least a half dozen times now...haha. Plus I can probably use it to pull my rear lca bolt when I install the rockstar skids.Have a slide hammer on hand. The clearance is so tight between the bearing and knuckle that even light rust in there can make it hard to get off.
Here in SoCal, yours should not be rusted in like in places that have real winters.
Mine came out with a light tap.
Yeah I'm hoping for the best being that I live in the desert.Here in SoCal, yours should not be rusted in like in places that have real winters.
I just want to be prepared so I'm not making multiple trips to get parts and tools..haha. Thanks for the heads up.I just pulled both of mine which were rusted badly. I had to use a 7 ton 3 jaw puller and barely got the passenger side off. I had to beat the shit out of it with a BFH before it finally popped loose.
Got the Fed Ex notification something shipped. Looks like I should have them and the gussets tomorrow. Unless they are orders for my wife...haha
Awesome. Thanks again for your help!Lol, she might have but your ball joints will be there tomorrow
I was completely surprised to find it so loose. I plan on pulling it into the drive way today and going over the whole front end. It was 8pm when I found it last night and was hoping retorquing it would solve it so my step son could drive it to school today. I need to check unit bearings too. Maybe I'll just do unit bearings and ball joints every 36k miles...haha. I was planning on prosteers but after hearing about how much of a PIA they are to rebuild I'll probably look at Crown or Oreilly. With selling the house I was thinking I may be able to do a PR44 when I get new tires and regear the rear in a few months, so I'm not wanting to invest a ton of money.
I have no experience rebuilding them, and while I don't doubt their quality, the price point for the ball joints and the rebuild kits was a bit higher than I cared to spend right now. Also I don't think I'd be able to tell the difference in new ball joints whether it be oem, synergy, or prosteers. Any new ball joint will be better over my worn ones...[emoji6]I must be one of the few that don’t find it bad to rebuild pro steers. The first lower was slow, but once I saw how it went it was really easy after that.
