Best coilover lift and axle choice?
Mjay
Huh? Not sure I follow. If you've looked around this topic is never ending and everyone has their own opinions.
I don't follow what debate you're talking about.
Are we talking about the c gussets?
Running the factory 44 on 37s?
Or saving up his money and only buying 1 aftermarket axle instead of a pr44 and then a pr60?
jeeper52
LOSER
Funny how the title says "BEST," yet we are contemplating so many things. Is it BEST for my budget. BEST for my wheeling style. BEST based on R&D?
For a JK the BEST is clearly DTD with a PR60/80 set up. That's what will be recommended and suggested because it has been proven over and over. Seen any JKX vids lately???
Seems like your mind is set on wanting to try out some new things and to go with the curries. If you want to run these, go for it. And then share with us your thoughts and frustrations later.
I understand if money were no option and you could afford to pay $125-150per hour the dtd with 60/80 dynatracs would be the way to go. However not many have $35k to drop on suspension and axles alone. Just trying to hit a happy medium thats all.
The axle debate. Everyone has an opinion on "what's best" or "what to run". That's all.
MTG
There shouldn't be a debate about it. Dynatrac axles are best money can buy. No questions asked.
Right. So the title of the thread should be the "Best coil over lift and axle choice, on my budget of $X?"
MTG
lol i honestly wasn't calling him a Liar at all. Its just he said something different than the manufacturer. Im sure both are right, maybe you can just run the coil overs without the bypass shocks and tune the coil overs accordingly?? To answer your question on why i dont run with the stock axles. I came from the utv polaris rzr crowd. I always found myself going on the harder more difficult trails and didn't necessarily have to worry about breaking because if i did i knew i could usually limp my way back to the trailer and haul it home. With the jeep since its my only way of transportation i cant risk a breakdown and getting stranded because i went on something my jeep wasn't ready for. Just thought since my axles are new and i can realize some money for them that i would do 60's right off the bat for a little extra insurance. Maybe im over analyzing all of this lol
Understood. Contrary to popular belief, your axles will not spontaneously explode if you install 37s and engage the 4wd. Or so I've heard. :crazyeyes:
With the lever system do you use the factory mounts on the axle?
It depends on which mount you're referring too. You must use their trackbar/bumpstop/heim bracket and install lower heim mount on the passenger side. I have the high clearance long arms made by EVO so everything fit perfect. The subframe bolted up 100% perfect for welding purposes.
jeeper52
LOSER
your right. I have a budget of about 25k for suspension and axles. Its tight i know but thats all i have. I think i can get around 4k for my whees/tires and front and rear axles then i can use that for drive shafts and maybe ram assist.
You can make it if you go with a pr44 and a trail 60 in the rear with Evo bolt on coilovers and 37's. You will have one hell of a capable rig with that set up.
jeeper52
LOSER
For example the genright kit requires you to weld on new brackets on the front and rear axle for the 3link up front and 4 link in the back. Does the lever system and dtd in the front require you to cut off the factory brackets and weld on all new ones to make it work?
jeeper52
LOSER
You can make it if you go with a pr44 and a trail 60 in the rear with Evo bolt on coilovers and 37's. You will have one hell of a capable rig with that set up.[/QUOTE
Can you run 40's on the evo coil overs later if i want with out cranking the hell out of the shocks to give you the height to clear them?
Short answer is yes.
