I decided to go junkyard axles because I could get more for my money in the end. The majority of the axles that people choose for this are Superduty axles or SD front with a newer GM 14 Bolt (AAM 10.5).
When it comes to SD axles you get a HP Dana 60 front and Sterling 10.5 Rear. 8x170mm bolt pattern. They are found in 99-04 F250/350 trucks. But be careful, many of these trucks came with a Dana 50 front which is smaller. Google it and look how to identify each. 99-04 are also leaf sprung so less casting to cut and cheaper wheel bearings for the front. They also have 30 spline outer stub shafts for the front.
05 and up axles are coil sprung so there’s plenty more casting to cut for the truss but adapt better for ABS and have 35 Spline outers.
Rear axle remains the same. 35 spline, disc brakes, and slightly offset to passenger side.
The reason why some people go with the GM 14 bolt is that the diff is centered and the 8x6.5 bolt pattern which means more wheel options. Centered diff means no interference with the JK tank. A newer 14 bolt will give you disc brakes and the width you are looking for. You will need to drill new holes in your front hub assembly to get the same bolt pattern or buy new front hubs. The 14 also hangs low limiting ground clearance. You can shave it but it’s more work and money.
I looked for several months at axles and the problem I ran into was most SD axles were Dana 50s when people said they were 60s and a newer AAM 10.5 was hard to find. I came across an 03 F350 with a complete set of axles for $800. This was easy and convenient. I didn’t need to find another truck for the rear or worry about all the casting. I was willing to tackle the tank issue.  I’ll explain later if the Sterling was the right choice or not.
Sent from my iPhone using
WAYALIFE mobile app
