Yeah, you got me thinking after the text you sent me and I figured I would just use the ARB switches sitting around.That looks good.
Are you going to wire up the rear to the ARB switch?
I looked into then locker bypass at the relays but think its easier just to go striaght to the rear for the ARB switch since its 12V anyways.
Plus in order to fit those switches I had to pull the circuit board out for the factory sway and locker buttons.
Sent from my SM-G986U using WAYALIFE mobile app
I was able to fit two switches and keep the factory one working but was going to bypass it regardless so I just cut it down and added the third.That answers my next question, of what it took to mount the switches there. I'm thinking about doing the same thing, since I won't have enough functions on a Switch Pro to run all I will need.
Pictures for wjtstudios. Let me know if you need more. View attachment 349108 View attachment 349109 View attachment 349110
Yeah mine is too. It bends down and loops back around near the battery box. Best picture I can get for now.How are your hoses on those reservoirs situated? My passenger side I’m struggling with the hoses being pinned to the underside of the battery box
Yeah mine is too. It bends down and loops back around near the battery box. Best picture I can get for now. View attachment 349203
Turn in a little.My fitting doesn’t point down like yours. I tried turning it earlier but no luck.
Mine came loose too, but only the bottom three. Just enough to make it leak[emoji24]
For the Dynatrac diff covers do you guys use loctite on those bolts? I would have thought the gasket maker would help keep the dynatrac 12-point bolts from loosening but unfortunately they came loose.
So how are you guys avoiding this problem with the rear sway bar hitting the brake line? View attachment 349384
Ok I did a search and found that method but was concerned if it should be hard mounted?You can run them through the frame. There is a hole on top and bottom right where the tab bolts on. It’s a pain but I’ve seen it done.
Perfect, I was unaware of the shrink issuse with the gaskets maker. Thanks!Gasket maker shrinks a bit when it cures. I usually let it sit overnight and re tighten them. Then again after a heat cycle or two.
