Went to adjust my tie rod to compensate for the bend and ended up snapping the sleeve adjuster. I noticed the sleeve slit had a twist to it already but didn't think much about it until it sheared.
Sheared and you can see the twist in the slit
What it should look like
Local part store had an adjuster sleeve in stock , nicer design with the hex head on it. Also picked up a rod end just in case
Got everything out
And new sleeve and rod end in
Now I just need to adjust the toe. Might have been fine to drive but I feel better knowing it's fixed. Need to save for a more beefy tie rod.
