As mentioned, you can replace one and then the other without any problems. Having said that, you do have a 2008 Unlimited with a manual transmission and so you won't "need" to replace your factory shafts any time soon. If being able to afford just one or the other is an issue, I would wait for one to start showing signs of failing and replace it first.
As far as running 1350 driveshafts on a D30 goes, the pros is that it'll be really strong and what you should be running with 37's or bigger tires. The cons is that it'll be stronger than your D30 components and if you're gonna have a break, it might be in it. Still, I would go with a 1350 regardless as you'll kick yourself later for not doing it when you can finally afford a PR44. :yup:
