Heholua
The front shaft isn't engaged in 2WD and the tires are all turning at the same speed. It shouldn't trigger the ABS/TCS system.
The wheel speed sensors tell the computer otherwise. You'll have two different rpms.
If all 4 wheels are on the ground the speed sensors are going to read the same. They are by the hubs not the driveshaft.
If it was me I would put the front axle on at home, pull the rear shaft and drive up and let the slap the rear axle in, drive home and put driveshaft back in and go wheeling.
The WSS read the tone rings attached to the axles. The only speed input change will be inside the TC.
Holy fuckin shit, just drop the front drive shaft and call it a day. I did and it didn't go into limp mode.
You're missing the point. You're trying to change the scenario to fit your needs. It's not gonna help.
EDIT ALERT! I'm well versed, so no need to read up. Maybe you should take your own advise before
making ludicrous statements about something you can't understand.
You actually make a lot of sense with some of the knowledgeable posts you have made on the forum, your problem is that you decided to be a prick when people question your logic. Work on that and you might become a decent contributing member.
Clearly you know more I or the engineers at Chrysler.
Hey Matt, there's your first hand knowledge!
Which gear ratio are you going to program the computer for?
Doesn't matter. If all 4 wheels are on the ground going the same speed....
The driveshaft pinion is going to be going a different speed but the sensors are reading the same.
Just drove my 2015 jeep 50 miles with 5:13's in the rear and 3:21 in the front with the drive shaft pulled.
Had it set for 5:13s.
Gotcha........my thought process was screwed up on this one.
If I wouldn't have just done it yesterday I wouldn't have been sure.
:thumb:
How far do you need to travel to the shop ?
Thats what ive been sifting thru this thread for lolol
